Author Topic: Cannot enter Settings>Images  (Read 3880 times)
WhoAmI
« on: September 10, 2014, 12:46:49 am »
In my component view I would like to replace an already existing object with an image. in order to do so i right click the object go to Apperance > Set Alternate Image and select an image i want to use. When selecting, a dialog box appears with the information "Error reading PNG file" (it doesn't matter whether it really is a png file or jpeg). If i go directly into Setting > Images i receive the same message (before even selecting any Image). What might be the reason for this?
Re: Cannot enter Settings>Images
« Reply #1 on: September 10, 2014, 12:56:40 am »
Never seen that, but probably someone clobbered the repository. You should remove the image, put in a working copy and change the references to use the new image.
