Author Topic: EA scripting not work on Windows 8(.1)!  (Read 3576 times)
mmo
« on: September 12, 2014, 06:25:01 pm »
As I had to learn there is a major issue with EA on Windows 8(.1): VBScripts do not run anymore (they don't even start and there is no error message or nothing - clicking on "Run" is like a No-Op), because the scripting environment in Windows 8+ has apparently changed such, that EA has trouble with it. The very same scripts run fine on Windows 7, btw.
I reported this >2 months ago, but Sparx support so far was unable to provide a solution. So I am bringing this to the forum in the hope that some other user may have found a solution or could at least provide me some hint what to try or install to remedy this.
I include Sparx' response to my problem report to avoid that others bother to provide the same suggestions:
We had the same issue with a Microsoft user using Windows 8.1. It seems the access to the VBscript.dll is not correctly supported in Windows 8.1.
Here are a couple of processes to check. Unfortunately we did not resolve exactly which process corrected the issue:
1) Try registering the DLL.
Open a command prompt (as administrator) and run the following command:
regsvr32 C:\Windows\SysWOW64\jscript.dll & C:\Windows\SysWOW64\vbvscript.dll
If the problem continues, try re-installing the Windows Scripting Service - see the following page for more information.
http://support.microsoft.com/kb/949140
2) Try also re-registering using regsvr32 the following:
\Program Files (x86)\Sparx Systems\EA\VEA\x86\SSAgent32.dll
\Program Files (x86)\Sparx Systems\EA\VEA\x86\SSScriptAgent32.dll
Let us know how you go with this.
Alas, none of these items helped or were even possible! All the mentioned .dll's don't even exist on my Windows 8.1 system and the hint behind the knowledge-base link suggests to install a stone-old windows scripting environment but its installer refuses to run (with error msg. "this OS version is not supported" or something similar)...
Has maybe anyone else found a way to get EA scripting back to life?
Michael
smendonc
  • I love YaBB 1 Gold!
Re: EA scripting not work on Windows 8(.1)!
« Reply #1 on: September 13, 2014, 08:40:49 am »
I ran one of the Sparx test scripts that gets installed - the one that counts elements in a package - and had no issues with VBScript on two different machines running Windows 8.1 (all latest patches installed).
A couple of thoughts:
  • Are you running Win 8.1 in 32 bit mode or 64 bit mode?  Both my tests were on 64 bit machines (one being a virtual machine)
  • I have a complete installation of visual studio 2013 on both machines.  Do you have VS on the machines you tested?  Just wondering if VBScript might have been enabled by VS.
Stan.
