Author Topic: Blue Screen of Death after latest OS update  (Read 41566 times)
Re: Blue Screen of Death after latest OS update
« Reply #15 on: September 09, 2014, 01:40:46 pm »
skiwi, perhaps this is sufficient motivation to upgrade to the latest build?
You better believe it.
 AYK I am a firm believer in using the current build.  :D
Just waiting for our apps guys to "allow-list" it ... ... ... ... ... ...
« Last Edit: September 09, 2014, 01:41:26 pm by skiwi »
Todd Beets
« Reply #16 on: September 09, 2014, 01:53:44 pm »
I can confirm that the new build (11.1.1111) did the trick in my case.  What a relief!   :)
AndyJ
  • It's only a model
Windows 7, SPI, 32 bit also affected by KB2993651
« Reply #17 on: September 19, 2014, 04:10:37 pm »
Hi peeps,
Just to let you know that this issue also affects the 32bit version of Windows 7 Professional, Service Pack 1.
We've just had KB2993651 pushed out here, and one of my users immediately started getting the BSOD when opening a diagram.
Upgrading to 11.1.1111 has solved the problem.
Andy
« Reply #18 on: September 23, 2014, 08:46:48 am »
Just to note I have had my first BSoD using build 1111
AndyJ
  • It's only a model
« Reply #19 on: September 23, 2014, 08:48:19 am »
Oh... poop.
What were the circumstances?
« Reply #20 on: September 23, 2014, 09:05:07 am »
Hard to say, working on a diagram, and then blue flash. Can't recall anything specific, but I'm diving back in there now, so I'll try to monitor what I do!
AndyJ
  • It's only a model
« Reply #21 on: September 23, 2014, 09:17:24 am »
The cynic in me is wondering if Microsoft are about to release "MS Enterprise Architect"
« Reply #22 on: September 23, 2014, 10:45:58 am »
Hehe. The now unsupported XP runs and runs and ...
« Reply #23 on: September 23, 2014, 02:59:05 pm »
OK, so two more crashes.
Both occurred when I was using the mouse to select multiple objects on a diagram by clicking and dragging to select the objects in the area of the screen.
FWIW clicked top right and selected diagonally down and to left.
« Reply #24 on: September 23, 2014, 04:30:04 pm »
I assume that it's not nice enough to provide a repeatable test case that you could send in. If I'm wrong about that, please do send us a model/steps to reproduce. It will be in some way related to the objects on a diagram.
What you can probably do right now to prevent the issue is set EA to use the basic renderer and disable GDI+ metafiles. At least that eliminated the issues we were having.
« Reply #25 on: September 24, 2014, 06:23:50 am »
I seem to be able to BSoD it at will, so I've sent it thru to support.
Thanks for the tips, I'll try them now.
« Reply #26 on: September 24, 2014, 07:52:54 am »
OK, so these settings live under Tools > Options > Diagram > Appearance
Changing GDI+ metafiles makes no difference to whether the BSoD occurs.
But a BSoD occurs every time with Render: Enhanced-1, but not Basic or Enhanced-2
hope this helps
« Reply #27 on: September 24, 2014, 07:58:01 am »
Thanks for sending in a bug report. When it became obvious that Microsoft wasn't going to release a timely fix we did our best to catch all the problems while we wait for a proper fix. Obviously there are some still around. Hopefully this one is something we can prevent easily. (Although the fact that it's only enhanced 1 renderer suggests a completely different problem. :( )
The main reason GDI+ metafiles would cause the problem is copying an element from a diagram. Depending on your settings that will include a metafile on the clipboard.
« Last Edit: September 24, 2014, 08:13:16 am by simonm »
RobVDSS
« Reply #28 on: September 24, 2014, 11:11:37 pm »
The information regarding updating to release 11.1.1111 in EA to prevent blue screening when accessing process models is extremely helpful; it worked without fail. Thanks
« Last Edit: September 24, 2014, 11:19:13 pm by iqbsrob »
« Reply #29 on: September 29, 2014, 06:19:39 pm »
Good work on 11.1.1112, great to have such a prompt update, thanks.
I look forward to checking it out asap
