Author Topic: Stereotype <<consumer>> changes appearance  (Read 4771 times)
Wilbert
« on: October 11, 2014, 11:00:10 pm »
When I change the stereotype of some element to <<consumer>>, the appearance of the element in the diagrams changes to a big triangle, without any content (I tried it on packages and node elements). I do not want this, but I did not succeed in changing this to a normal representation. Or is this some fancy UML thing, that I am not aware of?
By the way, my company uses EA version 7.5.850 (Build 850)
Gr., Wilbert
Re: Stereotype <<consumer>> changes ap
« Reply #1 on: October 12, 2014, 02:15:05 am »
The build is quite outdate (EA currently is at 11), but check the MDG settings. Probably it's enough to switch off all MDGs. If that helps turn on one after the other to identify the MDG causing the issue.
« Last Edit: October 12, 2014, 03:41:28 am by qwerty »
Re: Stereotype <<consumer>> changes appearance
« Reply #2 on: October 13, 2014, 09:10:52 am »
It's from the SOMF (Service-Oriented Modeling Framework) technology.
Wilbert
« Reply #3 on: October 14, 2014, 11:10:04 pm »
Thanks, that solved it...
Gr., Wilbert
