Author Topic: Inconsistent ea_guid value (v.9.3)  (Read 6071 times)
Hermont
« on: November 04, 2014, 11:15:36 pm »
Hello all.
Found an issue with EA when applying a user lock on a package. It indicates it's locked but when you try to change any value it doesn't allow the user to save the new information.
After looking at my SQL Server database I found there were inconsistent values for the ea_guid attribute between t_object and t_package tables.
After changing ea_guid value on the t_package table to match it's t_object table value the problem was solved but new issues keeps happening all the time. It looks like an application problem.
Anybody else got to see this issue?
Re: Inconsistent ea_guid value (v.9.3)
« Reply #1 on: November 05, 2014, 12:55:11 am »
Hard to tell. Especially as EA is now at V11 and you will likely not see any correction except you can reproduce that with V11.
