Author Topic: TaggedValues for connectors - bug in API  (Read 6532 times)
Stenvang
« on: November 10, 2014, 08:57:48 pm »
I've come to this problem which I think is a bug in the EA API.
EA has the ability to add a taggedValue to a connector. This is done in the properties of the connector (Same for elements and so).
However if I add a taggedvalue to a connector and then loops through the taggedValues for the connector in the API it throws an exception (see below).
foreach (TaggedValue tv in connector.TaggedValues)
      //Do something
But if there is no taggedvalue in the connector it doesn't throw an exception. So I can't access the taggedValues of the connector from the API which might be a bug.
Using EA v.10 and visual studio 10.
EXCEPTION:
Unable to cast COM object of type 'System.__ComObject' to interface type 'EA.TaggedValue'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{EF08950B-949E-435F-84A3-A59E3106C3BF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Re: TaggedValues for connectors - bug in API
« Reply #1 on: November 10, 2014, 09:42:47 pm »
I just ran a little test and had no issue accessing a TV for a connector.
Stenvang
« Reply #2 on: November 10, 2014, 09:47:58 pm »
Did you have a taggedValue added to the connector cause that's the only case I get the error?
If I haven't added a taggedValue to the connector it doesn't throw the error while I loop through them.
Stenvang
« Reply #3 on: November 10, 2014, 11:56:32 pm »
Could this be because of some dll it hasn't registered correctly? I can loop through the taggedvalues of packages and elements but not from the connectors...
This is weird.
« Reply #4 on: November 11, 2014, 12:56:16 am »
I'd try the usual suspects: User another machine/user. Re-install.
« Reply #5 on: November 11, 2014, 08:35:07 am »
EXCEPTION:
That's because the class you need to use is EA.ConnectorTag, not EA.TaggedValue.
Stenvang
« Reply #6 on: November 11, 2014, 06:03:04 pm »
EXCEPTION:
Ty Simon. That was the problem. Didn't realize that the API had different ways to access the taggedValues. But as I can see the same thing applies for methods, attributes and so.
