Author Topic: Output of an RTF Script without linebreaks  (Read 9984 times)
Dan M
« on: October 13, 2014, 10:49:43 pm »
I'm working on a RTF-Template for database modeling. Thereby I use a JScript within a template fragment which generates an output similar to the example on http://www.sparxsystems.com/enterprise_architect_user_guide/10/reporting/example_output_of_an_rtf_templ.html .
Now I am facing the following problem: When using the parameter formatted="1" no line break from the script output is displayed in the generated rtf-document. Without the parameter formatted="1" line breaks are displayed, but ofcourse without any formatting (e.g. bold, italic ...).
For example, let this be the script output:
<?xml version="1.0"?><EADATA><Dataset_0><Data><Row><testfield formatted="1">&lt;i&gt;textone&lt;/i&gt;\n\ntexttwo</testfield></Row></Data></Dataset_0></EADATA>
In the generated rtf_document it looks like this:
textone texttwo
But with formatted="0" it looks like this:
<i>textone</i>
texttwo
Is there a way to preserve linebreaks when using the parameter formatted="1" ?
Thank you!
Dan
Screwtape
Re: Output of an RTF Script without linebreaks
« Reply #1 on: October 23, 2014, 02:43:18 am »
I noticed the same. I was using a custom fragment script to display notes fields with formatting, and what you describe happend to me too. I noticed that the formatted seemed to be translating html tags to RFT, so I tried enclosing my notes data in <pre></pre> tags in a CDATA section, but they just appeared as text before and after my notes.
It seems that is only interprets certain tags.
I tried using
curElem.Notes.replace("\n","<br/>")
to replace line breaks with forced formatting, but that doesn't work either.
I suspect this is a bug, as the behavior is very inconsistent.
Screwtape
« Reply #2 on: October 23, 2014, 09:01:21 am »
I would try replacing \n with \r\n.
Screwtape
« Reply #3 on: October 23, 2014, 05:16:17 pm »
Thanks for the idea Simon, but it still just printed the <br/> rather than interpreting it. I suspect that it translates certain formatting tags, but not everything.
Screwtape
Screwtape
« Reply #4 on: October 25, 2014, 02:14:25 am »
Interestingly, I've just noticed, that the linebreaks are only removed if there are formatting tags in the note. If there aren't, and formatted="1" is still in place, the line breaks are fine.
I just changed single word to bold in the notes, re-generated the document and the word appeared bold, and the line break disappeared!
« Last Edit: October 25, 2014, 02:14:53 am by Screwtape »
Screwtape
Dan M
« Reply #5 on: October 25, 2014, 02:23:42 am »
I see the same behaviour in my environment. It really has the taste of a bug.
Regards
Dan
alesliehughes
« Reply #6 on: November 10, 2014, 09:29:04 am »
I tried using
quote]
try
curElem.Notes.replace("\n","&lt;br/&gt;")
Dan M
« Reply #7 on: November 11, 2014, 12:23:30 am »
I tried it but still it doesn't work.
 var xmlNotes = xmlDOM.createElement( "testfield" );
 xmlNotes.text=attribute.Notes.replace(/\r\n/g,"&lt;br/&gt;");
This gives the following XML:
<EADATA>
      <Dataset_0>
            <Data>
                  <Row>
                        <testfield formatted="1">&lt;i&gt;textone&lt;/i&gt;&amp;lt;br/&amp;gt;&amp;lt;br/&amp;gt;&amp;lt;br/&amp;gt;texttwo</testfield>
                  </Row>
            </Data>
      </Dataset_0>
</EADATA>
In RTF it looks like this:
textone<br/><br/><br/>texttwo
As Screwtape mentioned the following way doesn't work either:
  xmlNotes.text=attribute.Notes.replace(/\r\n/g,"<br/>");
This produces the following XML:
<EADATA>
      <Dataset_0>
            <Data>
                  <Row>
                        <testfield formatted="1">&lt;i&gt;textone&lt;/i&gt;&lt;br/&gt;&lt;br/&gt;&lt;br/&gt;texttwo</testfield>
                  </Row>
            </Data>
      </Dataset_0>
</EADATA>
and in RTF it looks like:
Do you have a running example? Could you please publish it?
Tank you.
Dan
alesliehughes
« Reply #8 on: November 11, 2014, 11:24:40 am »
Hi Dan,
After looking at this issue, I couldn't find a way to get the carriage return to obey. Please file a bug report and we'll start the process of correcting this issue.
Alistair.
« Last Edit: November 11, 2014, 11:25:01 am by alesliehughes »
Screwtape
« Reply #9 on: November 11, 2014, 09:15:16 pm »
Hi!
I've raised a bug (ref 14109186) along very similar lines a couple of weeks ago.
Yours,
Screwtape.
Screwtape
