Author Topic: Search for object_type gives strange results  (Read 3664 times)
ducatiross
« on: November 19, 2014, 01:54:46 am »
Hi
I wanted to use the Standard search facility to find all instances of a DataObject element I had created. However, regardless of what I used in the builder I could not find one.
I then resorted to writing some SQL :-
select object_ID, Object_type, Name, stereotype
from t_object
where stereotype = 'DataObject'
and this found a number of objects, but it proved that the Object_Type was 'Artifact', not DataObject.
Furthermore, when the results are displayed in the result window, it displays the Object_type column as 'DataObject' even when it is actually an 'Artifact' !
Using this SQL :-
from t_object
and Object_type = 'Artifact'
I get this as the first row
object_ID,Object_type,Name,stereotype,
814,DataObject,CRM4 XML File,DataObject,
Why does it do this ?
Are there any other objects that have a misleading Object_Type ?
Matthew
Re: Search for object_type gives strange results
« Reply #1 on: November 19, 2014, 02:46:05 am »
Some elements have different type in the table than presented in the API or GUI. It has been discussed here. I don't remember the reasons (claim it for history if you like) but that's as it is.
« Reply #2 on: November 19, 2014, 08:40:11 am »
In this case the explanation is simpler.
The SQL search window doesn't just display the results in the database. Object_Type is one of the columns with special handling. It shows the localized type, and in the case of stereotypes with _metatype set it shows that instead of the UML type that the stereotype applies to.
The easy solution is to change your SQL.
Select Object_Type as Real_Type from t_object
« Last Edit: November 19, 2014, 08:41:33 am by simonm »
