Author Topic: C# Web application run in EA Sequence Diagram  (Read 3970 times)
murukesan
« on: November 21, 2014, 10:43:27 pm »
C# Web application run in Enterprise Architect
I can possible to run C# Desktop application and do generate Sequence Diagram.
When i try to run a Sample C# Web application i couldnot get proper documentation to run the application.
I can possible to build the source in Enterprise architect.
I need a flow run the web application.
Please help to get a document or url link to view these details. ::)
« Last Edit: November 24, 2014, 03:12:21 pm by murukesanp »
Re: C# Web application run in Enterprise Architect
« Reply #1 on: November 21, 2014, 11:18:04 pm »
Nothing I can contribute but to clarify your question: You want to create a SD from a running web application by debugging it and have EA create the SD?
« Last Edit: November 21, 2014, 11:18:39 pm by qwerty »
murukesan
« Reply #2 on: November 21, 2014, 11:29:50 pm »
Thanks for your Replay
Yes . I want to create a Sequence Diagram when i run the C# Web application .
I had configure to build the application in EA. I want know how to configure to run the C# Web application .Where we need to provide the URL to access and debug to record .
Based on the record i want to create sequence Diagram.
In Debug  configuration in Execution Analyser to access the URL
Hope this data is sufficient .Please let me know if  :-/ :-/any data needed further.
« Reply #3 on: November 22, 2014, 12:27:41 am »
As said: not my area. But I guess others can put you on rails. There are quite some threads dealing with generating SDs from running code. Maybe you try he search button top left. Use "sequence diagram" for the search and extend the time to ALL.
murukesan
Re: C# Web application run in EA Sequence Diagram
« Reply #4 on: November 24, 2014, 04:19:38 pm »
I had added all PM List.Thanks for your support .Waiting for PMs reply
