Author Topic: Sequence lines force aligned below text or notes  (Read 4752 times)
MichaelBrietzke
« on: December 13, 2014, 04:54:09 am »
I cannot position a sequence line such that it is lined up with any text or note to the right of it. The line always repositions to a point below the bottom of the text or note. Can I turn this "feature" off? The work around is to move the note, position the line, then put the note where I want it.
Mike
Takeshi K
    • Sparx Systems Japan
Re: Sequence lines force aligned below text or not
« Reply #1 on: December 13, 2014, 09:07:14 am »
Hello Mike,
Maybe the issue is fixed on the latest build. If you use older builds, try the latest build.
t-kouno
