Author Topic: Element 'Foundation.Core.Association' is unexpecte  (Read 4337 times)
eerhosi
« on: November 26, 2014, 02:51:56 am »
I get the following error when starting Sparx EA version 11, what is the problem and what is the solution?
Error:
Code = 0x00ce014
Source = Line : 803; Char 89
URL: file///C:/Program Files (x86)/Sparx Systems/EA/UMLX13.dtd
Error Description = Element 'Foundation.Core.Association' is unexpected according to content model of parent element 'Behavioral_Elements.State_Machines.StateMachine.transitions'.
Expecting: Behavioral_Elements.State_Machines.Transition
Re: Element 'Foundation.Core.Association' is unexp
« Reply #1 on: November 26, 2014, 06:05:29 am »
Where did you get the XML from?
eerhosi
« Reply #2 on: December 17, 2014, 03:54:00 pm »
No idea. That XML is not familiar.
All this happened after I have created my own ArchiMate profile, most probably there is smthng wrong with the profile, perhaps I just have to remove the profile of mine..
This error message is shown on the startup, but I just close the msg box and continue working with Sparx EA 11..
« Last Edit: December 17, 2014, 03:54:24 pm by eerhosi »
« Reply #3 on: December 17, 2014, 05:07:18 pm »
The error is the failure to validate an XMI for a model against the DTD. I'm not sure of the circumstances an EA generated XMI file validates against that DTD, but it's not relevant for now. EA shouldn't be reading any XMI on startup.
I suspect that you have an XMI file (eg. For your own ArchiMate profile) in the MDGTechnologies directory (or another directory you've told it to read technologies from)
