Author Topic: MySQL ODBC - OLE DB Provider  [-2147217900]  (Read 8962 times)
ecsgz
« on: January 08, 2015, 11:49:01 pm »
please help and support me to solve this error, while trying to use MySQL server and EA. The EA_InnoDB schema has been set successfully before (http://www.sparxsystems.com/resources/corporate/index.html#sql_scripts) and a ea data model was successfully transformed to the database.
Error:
Microsoft OLE DB Provider for ODBC Drivers [-2147217900]
[MySQL][ODBC 5.1 Driver][mysql-5.6.22-log]Your have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Partition as Signed)' at line 1
Error occurs with software:
EA (32 Bit) Version: 9.3.5, 10.x
MySQL ODBC driver (32 Bit) Version 5.1.5, 5.1.13, 5.3.4
Community MySQL Server Version: 5.6.17 (@server, 64 Bit), 5.6.22 (@local, 64 Bit)
Desktop: Windows 7, 64 Bit
Description:
Access to EA model without any problem, except of this:
=> Login and connection to database via EA Tool without any problem. EA model can be accessed.
=> Everytime a diagram is opened (to which access is granted), the error warning occurs.
« Last Edit: January 09, 2015, 12:03:31 am by ecsgz »
Pawel Miechowiecki
Re: MySQL ODBC - OLE DB Provider  [-2147217900]
« Reply #1 on: January 09, 2015, 03:26:09 am »
MySQL from version 5.1 provides partitioning. Some SQL statements generated by Enterprise Architect uses word 'partition' because some of columns are called as the restricted key word 'partition'.
See:
select * from information_schema.columns where column_name='partition'The workaround is downgrade MySQL to 5.0 or earlier, but indeed this issue needs patch for EA :)
hd
« Reply #2 on: January 09, 2015, 07:38:31 am »
... or upgrade to the current build of EA. The MySQL Partition issue was fixed in build 1009.
jakson
« Reply #3 on: January 29, 2015, 01:21:47 am »
Like it was mentioned, this bug was fixed in newer EA versions:
Enterprise Architect 9.2 (9.2.921.23) - generates SQL error
Select * from t_xref where `Type`='swimlane' and Client='{...}' order by Cast(Partition as Signed);
Enterprise Architect 11 (11.1.1113.5) - no SQL error
Select t_xref.* from t_xref,t_diagram where `Type`='swimlane' and Client=t_diagram.ea_guid and t_diagram.Diagram_ID = ...  order by Cast(`Partition` as Signed);
