Author Topic: Deleted taggedvalue is still available in the API  (Read 5589 times)
Stenvang
« on: March 05, 2015, 10:46:49 pm »
A deleted taggedvalue was still available/visible in the API but not in EA.
I got an element with the following taggedvalues (from properties in EA):
Name: Something::SomeTaggedValue1 ; Value: 1;
Name: Something::SomeTaggedValue 2; Value: 2;
I created this little test method see below and got the following result from the same element:
Name: Something::SomeTaggedValue2; Value: 2;
Name: Something::SomeTaggedValue1; Value: ;
        public void showTaggedValuesOfElement(Repository repository)
            string message = "";
            Object item;
            ObjectType ot = repository.GetTreeSelectedItem(out item);
            if (ot == ObjectType.otElement)
                Element elm = (EA.Element)item;
                foreach (TaggedValue tv in elm.TaggedValues)
                    message += "Name: " + tv.Name + ", Value: " + tv.Value + "\r\n";
            MessageBox.Show(message);
So I guess that the two extra taggedvalues must have been deleted earlier.
Does any of you know anything about this?
Re: Deleted taggedvalue is still available in the
« Reply #1 on: March 05, 2015, 11:12:27 pm »
Check the "show duplicate tags" flag under the "settings" button above the tagged values.
Stenvang
« Reply #2 on: March 05, 2015, 11:28:40 pm »
Doh!
I guess I will just delete this topic..
« Reply #3 on: March 05, 2015, 11:46:23 pm »
Doh!
No leave it up here. There will be others that might get fooled by EA this way.  :D
