Author Topic: Dao database error  (Read 5592 times)
razzo78
Dao database error
« on: March 11, 2015, 08:59:08 pm »
Hi, i have enterprise architect 12 corporate. I have dowloanded the epmty project EABase350.zip in http://www.sparxsystems.com.au/registered/reg_ea_projects.html
I use this model as template for my project.
I have create a Domain Model but now, if i add a relationship between two object wher i delete it i always obtain the following error:
DAO.Database [3201]
You can't add or change a record because a related record is required in table 't_object'
What is? how do I remove it?
Re: Dao database error
« Reply #1 on: March 11, 2015, 10:52:12 pm »
You should delete that file and download it again. It's likely broken during transmission (this happens, though very rare).
Maybe you should use the Jet4 version: http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1425907745/4#4
« Last Edit: March 11, 2015, 10:54:36 pm by qwerty »
razzo78
« Reply #2 on: March 12, 2015, 08:09:23 pm »
I have exported the contet of file in xml, then i have imported them to a new empty file, and the problem was fixed
