Author Topic: EA 12: Connect to VS Project doesnt work  (Read 6432 times)
Raf L.
« on: March 01, 2015, 08:53:45 pm »
I'm running VS2013Upd4 and EA 12. I installed VSIntegrate version 5.
Extensions->Visual Studio->Connect to External Project brings forth the "Visual Studio Connections" Dialog box, and pressing "Browse" allows me to select a sln file, but then nothing happens.
Also, the "Help" button does not work in that dialog. Please, where can i find up-to-date guidance in making this connection?
SomersetGraham
Re: EA 12: Connect to VS Project doesnt work
« Reply #1 on: March 02, 2015, 07:48:20 pm »
Hi
The user guide can be found here -
http://
http://www.sparxsystems.com/bin/MDGIntegrationVS4.pdf
I use VS2012 integrated with EA
You need to connect EA packages to a VS project, not a model to a solution file
Using V12
sparxstevebe
« Reply #2 on: March 07, 2015, 02:54:55 pm »
[size=12]Hello,[/size]
I have a similar issue. I'm able to trigger the connection from EA project to a VS solution as Raf L. wrote, but on my side the result is an error dialog, saying:
An error occurred while attempting to communicate with an Addin:
Visual Studio (EAVSBridge.EAVSAddin)
"MDG_Connect: Invalid Parameter(s)"
Please contact the add-in provider for assistance.
So I'm here to do so. Hope, I'm right. ;-)
In the other direction I do not have any option to connect my solution with an EA model: not in the project menu, any other menu nor in the context menu of my solution -- as the VSIntegration demo explains.
It seems, that VS do not have access to the MDG Integrate plugin. But it is installed, as the programs&features system control lists it. I cannot find any traces from within VS.
My Dev-Environment is:
  • Win7
  • VS2013
  • EA12 Trial
  • MDG Integrate 5 Trial
  • C++ console application project
What I'm doing wrong?
How to check, if it is installed correct?
How install it otherwise?
Any advise would be very appreciated. Best regards.
PS: The trial period both is still active for EA and MDG Integration.
« Last Edit: March 07, 2015, 03:21:12 pm by sparxstevebe »
SomersetGraham
« Reply #3 on: March 09, 2015, 07:26:25 pm »
Hi
The one thing that I had to do to get this working -
Open your solution file with a text editor
Locate the section that adds the eap file or short cut - it looks something like -
     ProjectSection(SolutionItems) = preProject
            ..\..\Model\ModelShortCut.EAP = ..\..\Model\ModelShortCut.EAP
      EndProjectSection
EndProject
No move this section to the top of the solution file and reload
Using V12
sparxstevebe
« Reply #4 on: March 11, 2015, 09:28:56 am »
Hi SomersetGraham,
does this reveal the additional views of EA within VS? I'm looking for the model browser and diagrams view of EA right in VS.  :-/
I will take a look...
Best regards
SomersetGraham
« Reply #5 on: March 11, 2015, 07:50:55 pm »
Hi
If the EA Model view is not visible in VS you need to attach the model
Project->Attach UML Model
Using V12
sparxstevebe
« Reply #6 on: March 13, 2015, 10:20:23 am »
unfortunately it does not work. :-(
I have the "Solution Items" folder as the first node in the solution. The folder contains the EAP file. In the right-click menu of that EAP I can choose "open with..." and through "more" can find an entry for "Enterprise Architect ...". So I guess, there is "some" integration of VS and EA. But there is still no entry called "Attach UML Model" in PROJECT menu: not if selected the first node, not if selected the EAP file and not if selected the Win32Project1 project.
Can you find any other entry/action within VS related to EA? Maybe in the project properties of your code project, maybe else. I don't.
I tried to "repair" the VSIntegrate installation from within the programs system control with no luck. Seems that there is something broken.  :'(
Is there somebody of the Sparx staff that reads this? Do I have a misconfigured system, or made a mistake when installing? Don't know what to do, to get the VSIntegration working properly.
Best regards,
/me
« Reply #7 on: March 13, 2015, 10:30:26 am »
Yes, but not the one you need. Send in a bug report using the link at the bottom of the page or email [email protected]
sparxstevebe
« Reply #8 on: March 15, 2015, 07:35:15 am »
Hi KP,
thanks for your answer. Yes indeed I thought about that. But wasn't sure if it is an error on my side. So I had to choose my own bug reporting system. :-D
Ok, lets try it. Hopefully it will help.
Best regards
/me
