Author Topic: EA 12 Import DB schema from Project Browser  (Read 6103 times)
« on: March 23, 2015, 02:51:49 pm »
EA 12 Corporate edition Import DB schema using Project Browser context menu
Using the project browser
  • unlock package
  • context menu for package
  • Code engineering > Import DB schema from ODBC
nothing happens
Has this functionality been deprecated in favour of the data base builder and someone forgot to remove it from the context menu?
RoyC
  • Read The Help!
Re: EA 12 Import DB schema from Project Browser
« Reply #1 on: March 23, 2015, 03:58:09 pm »
It worked for me just now, on a MySQL database.
Best Regards, Roy
« Reply #2 on: March 24, 2015, 06:41:05 am »
Interesting, thanks. I'm using a SQL Server repository.
I can get to the dialogue via the Database Builder, but no longer via the code engineering menu, hmmm, I'll see what else I can find out
« Reply #3 on: March 24, 2015, 11:50:42 am »
Well you know what.
RoyC - I'll bet when you did this you had a diagram from the database folder open.
So here is the thing, EA should provide an error message saying "you can't import a DB schema as you haven't opened a diagram from the database folder"
Sorry, I gotta a say this (after wasting my time), EAUI, and I guess bug/feature request.
RoyC
  • Read The Help!
« Reply #4 on: March 24, 2015, 02:00:21 pm »
Well, how MUCH would you bet? I'll take NZD by bank draft or direct transfer. Or - in true gambler style - any fancy sports car, work of art or property in Ponsonby or on the bay.
I didn't have any diagram open, and I've wandered around several of my 'sandbox' models without going near the database builder. If I have any concern it's that it seems to be TOO easy to import from a database via ODBC - my sandboxes are now full of imported Tables that I have no real need for.
Best Regards, Roy
« Reply #5 on: March 24, 2015, 02:44:31 pm »
Well that's cute, I shall have to look into it further, but it appears definitely to be the cause for me!.
PS sorry, I'm a Wellington aficionado.
PPS thanks
RoyC
  • Read The Help!
« Reply #6 on: March 24, 2015, 03:37:50 pm »
I can't test SQL Server at the moment. I'm not a DB expert by any means, but perhaps there is something in the database type? I'll see what others might say.
You like Wellington boots? Well, I prefer Aussie Blundstones, so I'll let you off the bet.
**EDIT: The nearest thing we have to a DB Guru (AND IT'S A CLOSE-RUN THING) also cannot replicate the problem, so send us a bug report with your Package structure so that we can analyze it in more detail. Unless you have already done so.
« Last Edit: March 24, 2015, 05:03:16 pm by RoyC »
Best Regards, Roy
