Author Topic: Complex Views Truncated  (Read 4355 times)
JNHL
« on: March 24, 2015, 08:52:23 pm »
I'm currently using an evaluation copy of Enterprise Architect 12.
When importing complex views from SQL Server 2012 (SP2) I've noticed that the code is truncated during the import process.
I suspect this is due to the use of the INFORMATION_SCHEMA.VIEWS which hold a truncated version of the code due to the VIEW_DEFINITION field being a NVARCHAR(4000).
Surely a better option would be to use the sys.sql_modules view which holds the definition in a NVARCHAR(MAX), or the OBJECT_DEFINITION() function.
There may be a compatibility issue with the sys.sql_modules and the OBJECT_DEFINITION() function which are only available in SQL 2005 and Later.
I have complex SP's that are greater than 4000 characters, but they appear to be importing ok.
(Edit due to additional research)
« Last Edit: March 24, 2015, 09:08:14 pm by EDWCLtd »
