Author Topic: EA12 Find Orphans shows signals in diagrams  (Read 4969 times)
gtsoftware
« on: March 25, 2015, 09:15:51 pm »
(EA 12.1.1207 Corporate on Windows 8.1)
I used 'Find in Project', Diagram Searches, Find Orphans and noticed a few signals that I know are used. I right clicked a signal and choseĀ 'Find in Diagrams'; it shows a messages sequence diagram using the signal.
Is this a bug or am I using Find Orphans incorrectly?
Cheers,
Colin
Re: EA12 Find Orphans shows signals in diagrams
« Reply #1 on: March 26, 2015, 09:53:56 am »
Find orphans shows elements that don't directly appear on a diagram. Which signals often don't.
In contrast, the find in diagrams functionality has been updated over the years to detect a number of additional ways that things are used.
gtsoftware
« Reply #2 on: March 26, 2015, 08:29:45 pm »
Hi Simon,
Thanks for confirming that it is an issue. Is reporting it here enough or should I raise it elsewhere with a sample model that demonstrates it?
Colin
« Reply #3 on: March 26, 2015, 08:43:35 pm »
Colin,
I'm not sure Simon confirmed this is an issue.
I think he's merely indicating that both features look at things in a different way.
In anyway, it is never enough to post an issue here. You'll have to submit a formal bug report to get something moving.
gtsoftware
« Reply #4 on: March 27, 2015, 08:15:05 pm »
Hi Geert,
You're right. I did raise the same question as a bug report and EA have promptly replied that it is indeed working as expected. I'm told that the signal is a 'classifier' so the signal doesn't (itself) actually appear on the diagram, hence EA is working as expected.
I find that deleting the orphan signal still leaves the text on a message sequence chart but when I make other message sequence chats I can't just select the existing signal (because it has been deleted). My workaround is simply to add a diagram of signals so they're not orphan any more.
Colin
