Author Topic: Disable nesting in project browser  (Read 5087 times)
JoMa
« on: March 31, 2015, 11:37:21 pm »
Dear EA-Users,
unfortunately I run into a problem using properties with decomposition and detailed modelling.
Following the method of Oliver Alt (German trainer at OOSE) I build a library containing blocks. In the project model I use properties only. Now I'd like to build a decomposition diagram for functional analysis. That works. But if I model a function in detail using FlowItems in a ibd the subfunctions get nested. So the bdd with the decomposition gets "destroyed". Locking the property helps to avoid the nesting, but every time I move a property I get a warning message.
Is there any other solution? May it be possible to disable the auto-nesting?
Thanks in advance!
Cheers
Markus
Re: Disable nesting in project browser
« Reply #1 on: March 31, 2015, 11:43:33 pm »
Markus,
I think the option in Tools|Options|Objects|Support for Composite Objects is what you are looking for.
JoMa
« Reply #2 on: March 31, 2015, 11:49:10 pm »
Hi Geert,
that is what I need, thank you very much!!!
Markus
