Author Topic: EA11 - Generating Triggers DDL  (Read 4746 times)
Morcous
« on: April 01, 2015, 08:38:34 am »
Hello, I'm a little new to EA (only been using it for a few months), and I'm new to these forums.
I'm seeing an issue with DDL generation of Sequences.
For a sequence (on OWNER.TABLE_NAME), it generates:
--  Create Triggers
CREATE SEQUENCE owner.sequence_name
    INCREMENT BY 1
    START WITH 1
    NOMAXVALUE
    MINVALUE 1
    NOCYCLE
    NOCACHE
    NOORDER
CREATE OR REPLACE TRIGGER owner.TRG_table_name
      BEFORE INSERT
      ON table_name
      FOR EACH ROW
      BEGIN
            SELECT owner.sequence_name.NEXTVAL
            INTO :NEW.column_name
            FROM DUAL;
      END;
The problem is in bold... the TABLE_NAME isn't being prefaced by the Owner name. Does anyone know a fix? Is this a bug?
hd
Re: EA11 - Generating Triggers DDL
« Reply #1 on: April 02, 2015, 08:15:44 am »
With EA version 12, you can modify the DDL Generation template to add the owner name to the table name.
Open the DDL Template editor from menu Package | Database Engineering | Edit DDL Templates...
Select Language: Oracle, then select the DDL Column Extras template. In the CREATE TRIGGER statement near the bottom of the template, change the line ...
$trigger += "      ON " + $tableName + " \n"to ...
$trigger += "      ON " + $owner + "." + $tableName + " \n"
Morcous
« Reply #2 on: April 02, 2015, 08:34:05 am »
Thank you for the reply, gne.
I tried looking for similar functionality in EA version 11 and couldn't find it.
Can you confirm that it doesn't exist in version 11?
« Reply #3 on: April 02, 2015, 09:01:58 am »
There were no DDL generation templates in v11
