Author Topic: EA11 - Renaming Sequences for AutoNum columns  (Read 3556 times)
Morcous
« on: April 03, 2015, 04:05:28 am »
Is there a way to specify the default name for a Sequence or Trigger when using the AutoNum property to generate it in the DDL?
Right now, when I set an identity column to be AutoNum=True, it generates a sequence and trigger in the ddl with the following names:
SEQ_TableName_ColumnName
TRG_TableName_ColumnName
I'd like it to generate SEQ_ColumnName (since many of our tables are very long, and the identity column names will match the table name with an _id at the end)
Is there a way to do this in EA11?
Thank you
