Author Topic: EA10 - Cannot Delete MDA Templates  (Read 4479 times)
bakerman807m
« on: April 07, 2015, 02:41:53 am »
While working on MDA Templates, I could not find any way to delete a Transformation Type. I can easily add them with the "New Transformation Type", but there does not appear to be any way to remove one I have created, unless I am missing something.
We are using EA Ultimate in a shared repository.
« Last Edit: April 07, 2015, 04:40:12 am by bakerman807m »
Aaron B
Re: EA10 - Cannot Delete MDA Templates
« Reply #1 on: April 08, 2015, 12:47:57 pm »
If there are no modified templates saved for your new transformation then it will simply disappear after you close and re-open the transformation editor.
Look down the list of templates.  If you see any which show "yes" in the modified column, select this template and click the Delete button.  After each modified template of your transformation has been deleted, close and re-open the editor and the transformation should no longer be visible.
