Author Topic: "DAO.QueryDef [3035] System resource exceeded"  (Read 16941 times)
suki
« on: April 14, 2015, 12:46:34 am »
i'm using Enterprise Architect 11 Corporate edition with local EAP project. Now I am not able export whole project to HTML (Publish as HTML). I always get the error message "DAO.QueryDef [3035] System resource exceeded" almost immediately after pressing the button "Generate".
I have found some advices on net with modification register's setting: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Jet\4.0\Engines\Jet 4.0
"MaxLocksPerFile"=0x0000251c (9500) => increased this default value
....but it didn't help me.
Checked with OS:
Windows 7 Ultimate SP1 64-bit
and
Windows Server 2008 SP1 64-bit
The result is still the same.
Any ideas please?
Re: "DAO.QueryDef [3035] System resource exceeded"
« Reply #1 on: April 14, 2015, 02:10:51 am »
Without a real clue: the repository might be corrupted. Try setting up a new one using XMI ex-/import and see what happens with the new repository.
suki
« Reply #2 on: April 14, 2015, 02:27:45 am »
I've already tried this. All packages are under subversion control. So i did "Import model Branch.."
Unfortunately the result is still same. I can provide additional information if necessary. Currently I have no idea how it resolve.
Thank you in advace.
« Reply #3 on: April 14, 2015, 02:35:59 am »
Did you create a new model from scratch? That's different to just reload from VC.
suki
« Reply #4 on: April 14, 2015, 05:06:55 pm »
Yes, I created completely new.
  • I created New model (empty)
  • I set up Version Control Settings (to establish connection with SVN)
  • I started import from root package clicking at .EAB file in svn
The repository is large. I had to make "Compact .EAP file" few times to finish whole import process.
« Reply #5 on: April 14, 2015, 07:18:03 pm »
In that case you should contact Sparx support via mail. They are quite responsive when it comes to such kind of issues. Good luck and keep us informed.
