Author Topic: CTRL-DEL pressed in Notes deletes edited item  (Read 3571 times)
Bohusz
« on: April 30, 2015, 10:28:31 pm »
When I'm editing Notes of an operation of a class (in Features window) and press CTRL-DEL, the operation is deleted immediately. As there is no Save button in version 12, there is no way, how to remedy the situation. All operation's definitions including parameter definitions and their documention is lost forever.
CTRL-DEL, as you might know, in the most of editors deletes the text starting the cursor position upto to the next word ending (to the right). I use it for years without thinking. Just minutes ago I lost quite a long description of how to implement the method (I use notes because they can be formatted and are included in generated Java code in contrast to Behavior field). :-/
And yes, I tried to disable the key mapping in Tools / Options, but it's not there.
-- Bohusz
Re: CTRL-DEL pressed in Notes deletes edited item
« Reply #1 on: May 01, 2015, 12:19:34 am »
Please report a bug. Use the link bottom right of this page.
