Author Topic: Cannot generate documentation from model  (Read 6083 times)
Jan Prikryl
« on: May 07, 2015, 12:28:20 am »
Hello everyone,
I feel this must be some quite obvious misconfiguration of my EA Profession Edition, but I am unable to find what went wrong:
I have a software model containing several Use Cases, a Class Model, a Component Model and some Activity diagrams. Now I would like to generate documentation report -- but the documentation menu options (RTF/DOC/HTML/...) that should appear in the Project Browser menu for documentation (see the left image) or in the drop-down menu for a package (see the right image) are not there ...
I have tried fresh installs of EA 9, 10, and 11 on three different computers that I use and everywhere it is the same. Also, I have tried several different models, and also the default "Example Model", but still I have no luck in getting the appropriate menu displayed. The F8 shortcut does not work as well.
Does anyone have an idea what did I do wrong? I am definitely not an EA expert, and it is likely that I simply forgot to specify something somewhere.
Thanks for any hint ...
-- jan
Aaron B
Re: Cannot generate documentation from model
« Reply #1 on: May 07, 2015, 09:22:34 am »
It's possible you have selected a Menu Set which hides these menu items.
In EA 12, Open: View | Perspectives > Menu Sets.  To show all available menu options, select the "Complete" menu set.
For help regarding this feature, see:
http://www.sparxsystems.com/enterprise_architect_user_guide/12.0/getting_started/customize_command_sets.html
(Edit: Just realized you said you were working with EA 9, 10 and 11, not 12.)
In EA 11, Open: View | Workspaces and Commands > Commands.  To show all available menu options, select the "Complete" command set.
http://www.sparxsystems.com/enterprise_architect_user_guide/11/getting_started/customize_command_sets.html
« Last Edit: May 07, 2015, 09:24:43 am by AaronB »
Jan Prikryl
« Reply #2 on: May 07, 2015, 07:30:55 pm »
Thanks Aaron, that was it.
I had just the Software Development command set active and this set does not include Documentation menu ...
-- jan
Uffe
« Reply #3 on: May 07, 2015, 08:23:11 pm »
Da-da-dum dum dum
Command Set strikes again
Da-da-dum dum dum
Half my menus are gone
Can't get anything done
And I don't know what to do
Hey - it's gonna get you too
« Reply #4 on: May 08, 2015, 12:25:36 am »
If it was only Command Set. They also got the EAster syndrome to hide menus with each release at another place. Since the very beginning! I guess Sparx is the home of the Easter bunny.
