Author Topic: Problem with setting up SQL Server Repository  (Read 5683 times)
STV
« on: May 12, 2015, 01:32:40 am »
Hi everybody
We have been using Enterprise Architect 10.0.1008, projects have been saved file-based up to now.
Now we'd like to use EA with a Database Repository under MS SQL Server SP1.
According to http://www.sparxsystems.com/enterprise_architect_user_guide/8.0/projects_and_teams/upsizingtomysql.html, the following steps have been carried out:
  • A new database has been created using the Script provided under Link above
  • "Stage Five: Transfer the Data": everything entered as advised. We have a Group Enterprise_Architect which has been set up for read and write access to our DataBase EnterpriseArchitect --> we use Single-Sign-On --> Testing of the connection is successful!
Now click on the Transfer button and as soon as the progress bar is at about 50% and "copying project information for: t_category" is performed, the following error message occurs:
Microsoft OLE DB Provider for SQL Server [-2147217900]
Cannot find the object "t_category" because it does not exist or you do not have permissions.
Checks from our side:
  • The Table t_category exists
  • it can be accessed e.g. via Excel
Any hints are highly appreciated!
Best regards, STV
OpenIT Solutions
Re: Problem with setting up SQL Server Repository
« Reply #1 on: May 12, 2015, 02:14:13 am »
As it happens I saw the same error last week - the fix for me with to run the project consistency check on the EAP and fix the errors reported. Then trying the migration again....
STV
« Reply #2 on: May 12, 2015, 04:44:28 pm »
Thanks for your suggestion! Just executed Tools --> Data Management --> Project Integrity Check. Result: No problems found - and same error when trying to transfer the project again...
« Reply #3 on: May 12, 2015, 05:19:17 pm »
The link you provided talks about MySQL in EA version 8, but you mentioned EA v10 with SQL Server?
Are you sure you are following the correct instructions?
« Reply #4 on: May 12, 2015, 05:22:21 pm »
It's actually a permissions problem on the SQL server
Somewhere in the instructions it states
"When transferring a project you must have db_ddladmin permission in order to execute the SET IDENTITY_INSERT ( table )  {ON | OFF} command"
