Author Topic: generate DDL - oracle sequence name length limit  (Read 8773 times)
Bruce Thomason
« on: May 21, 2015, 04:34:54 am »
Background:
Oracle native sequence name lengths are 30 characters.
DDL generation from EA for autonum fields can result in a longer sequence name - the SEQ appears to use both the table name and field name.
Question: is there a means to control the sequence's name construction pattern name through DDL templates or otherwise and/or to have EA honor the Oracle name length limitation?
rsharma
Re: generate DDL - oracle sequence name length limit
« Reply #1 on: February 01, 2018, 09:40:43 pm »
Hi
I am experiencing the same issue stated above. Was a resolution/workaround discovered?
« Reply #2 on: February 01, 2018, 09:54:41 pm »
Hi rsharma
From Oracle 12.2 and above character limit is increased.
Please refer https://docs.oracle.com/database/121/SQLRF/sql_elements008.htm#SQLRF00223 for more details
« Last Edit: February 01, 2018, 10:27:15 pm by Arshad »
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
« Reply #3 on: February 01, 2018, 10:24:10 pm »
Background:
You can try to if configuring Name Template from 'Settings | Project Options | Source Code Engineering > DDL: DDL Name Templates'  would help
or go to DDL Template Editor -> Oracle, and edit the $SeqName variable construction. It uses a template call $DDLName% which takes into account parameters like "Include_Owner", "Include_Surround". Trial with these to adjust Name
