Author Topic: what is a SSRunPr tag  (Read 8196 times)
« on: June 16, 2015, 12:42:19 pm »
Does anyone know what are these SSRunPR tags in EA generated documents?
Why are they there, and how do I stop them being generated?
Re: what is a SSRunPr tag
« Reply #1 on: June 16, 2015, 03:55:38 pm »
Nope, never seen such weird tags in my generated documents.
reherz
« Reply #2 on: October 20, 2016, 11:20:17 pm »
I have the same problem with the SSRunPr - tags! Does anyone else has these tags too?
@skiwi did you find a solution?
Uffe
« Reply #3 on: October 21, 2016, 12:33:05 am »
IIRC, they're to do with hyperlinks. You can get rid of them with the following snippet.
Code: (VBScript) [Select]
sub PostProcess(fileName)
dim wordApp
dim wordStarted
on error resume next
set wordApp = GetObject(, "Word.Application")
if (err.Number = 0) then
wordStarted = false
else
set wordApp = CreateObject("Word.Application")
wordApp.Visible = False
wordStarted = true
end if
dim doc
set doc = wordApp.Documents.Open(fileName)
dim xmlNode
dim i, count
count = doc.XMLNodes.Count
for i = count to 1 step -1
set xmlNode = doc.XMLNodes.Item(i)
if (xmlNode.BaseName = "SSRunPr") then
xmlNode.Delete()
end if
next
doc.Close(-1)
if (wordStarted) then
wordApp.Quit()
end if
end sub
If you're using a script to generate the document, and this issue is a good reason to, you can integrate the fix into the same script.
/Uffe
