Author Topic: Creating elements by selecting text in a LinkedDoc  (Read 3665 times)
stevesavage
« on: July 28, 2015, 05:18:23 am »
I make heavy use of Sparx EA's ability to import Linked Documents as RTF files so I can trace requirements and other artifacts explicitly to statements taken from these source documents.
Details of how I do this can be found at http://stevenksavage.com/?p=22
Unfortunately step 3.1 no longer works. When I do the following steps:
Select the text that you want to create a Statement from
Menu: right click on the select text -> create -> new -> other
In the “New Element Dialog”, Select Toolset -> requirements
Select Type: Requirement
In Stereotype: type “statement”
Press Create
Previously at this point Sparx EA would create the new Element, and the selected text would now be a hyperlink to the new Element.
Now, Sparx EA still creates the element, but instead of creating the hyperlink it deletes the selected text.
Create -> New Requirement works as expected.  But not Create -> New -> Other
« Last Edit: July 28, 2015, 05:22:12 am by realitystorm »
