Author Topic: URGENT >>> DAO.Database [3197] error  (Read 5759 times)
BasicSystems
« on: August 01, 2015, 04:48:54 am »
Error text:
An error has occurred loading the requested project
I AM FULLY BLOCKED BY THIS ERROR
THERE APPEARS TO BE NO PREVIOUS POSTS OR DOCUMENTATION
HARD TO BELIEVE GIVEN THE SEVERITY OF THE ERROR
Repro
- I have a Parallels VM running my licensed single user copy of EA
- I need to open my .eap from a VMWare box so I can import a SQL Server schema - this is my dev env
- I installed EA on the VMWare VM
- I setup an ODBC and successfully imported the db scema
Now when I attempt to open the .eap from either installation of EA I get this error
DAO.Database 3197
The Microsoft Jet engine stopped by process because you and another user are attempting to change the same data at the same time
I have tried renaming the .eap file
Renaming / deleting the .ldb files
Nothing works
This is a full blocking issue PLEASE HELP
BasicSystems
Re: URGENT >>> DAO.Database [3197] error
« Reply #1 on: August 01, 2015, 04:53:19 am »
Ok; my bad for not trying to repair. That worked
Not entirely obvious solution but worked
To EA - love your tool BUT please document this error and how to fix it
