Author Topic: EA shutsdown using generate with custom template  (Read 3985 times)
Charlie7000
« on: September 07, 2015, 07:48:17 pm »
I couldn't find a similar error, so decided to post my issue here.
I still use Version 11.0.1107
I created my own custom template, copied from Diagrams Only. I only customized the header.
Every time I select my own custom template when I generate the document, the system shuts down. Error message are: A problem caused the program to stop working correctly. Please close the program.
What should I do?
VKN
Re: EA shutsdown using generate with custom templa
« Reply #1 on: September 08, 2015, 09:46:26 am »
  • Export the template (Project | Data Management | Export Reference Data)
  • Import into another .eap then generate the document
  • If you come across the same thing then send your template to sparx support
« Last Edit: September 08, 2015, 09:47:04 am by VKN »
