Author Topic: EA 12 - Invoking Update() on Connector -> EA Cr  (Read 4507 times)
Tomasz
« on: September 08, 2015, 12:42:53 am »
I was working very long time on implementing C# plugin for generating custom communications diagrams. And it was working great until version 12 appears :(.
I have found that there's a significant change in internal API (in ver.12) implementation, which causes EA crash when I'm trying to Update() programatically instance of Connector class.
After some investigation I have found that for some reason, some person decided that now it's impossible to create and Update()  Connector instance with type 'Collaboration' between:
- 'Actor' and 'Object' or even between two 'Object's
Of course it's possible to create that manually. I checked exported xml file and I have found that:
<UML:TaggedValue tag="ea_type" value="Collaboration"/>
<UML:TaggedValue tag="direction" value="Source -&gt; Destination"/>
<UML:TaggedValue tag="ea_sourceType" value="Actor"/>
<UML:TaggedValue tag="ea_targetType" value="Object"/>
It worked perfectly in previous version 10 and 11.
Could someone can help me ?
Thank in advance.
Code pieces:
//simple connection between Actor(root of diagram) and first class 'Object'
EA.Connector connector = previous.m_diagramElement.Connectors.AddNew("", "Association");
connector.SupplierID = current.m_diagramElement.ElementID;
connector.Direction = "Source -> Destination";
//Manually you should  'Add Message from XX to YY" by selecting from previously created connector on diagram submenu (RMB)
//To achieve the same programatically I created message connector
EA.Connector message = previous.m_diagramElement.Connectors.AddNew(functionData.MethodName, "Collaboration");
message.SupplierID = current.m_diagramElement.ElementID;
message.Direction = "Source -> Destination";
connector.Update();
message.SupplierEnd.Ordering = 1;
message.ClientEnd.Aggregation = connector.ConnectorID;
message.ClientEnd.AllowDuplicates = true;
message.ClientEnd.Ordering = 1;
message.Update() <<--------------- Here is a crash
When I use try catch statement, the exception message is:
'Collaboration' is not legal for Actor --> Object' !!
Why it's possible to do it manually, I don't understand  :(
Is it possible to set in C# code that I want to use Lib with version 10 or 11 ?
« Last Edit: September 08, 2015, 12:47:04 am by tomaszlewandowski »
Re: EA 12 - Invoking Update() on Connector -> EA C
« Reply #1 on: September 08, 2015, 05:21:59 am »
Faintly and eventually unrelated I remember a discussion. Try turning off Package/Model Validation/Configure all options (and turn them on back until the error comes back, then leaving this one off).
Aaron B
« Reply #2 on: September 08, 2015, 04:44:17 pm »
We have had reports of similar problems with creation of other connector types via automation and we have resolved this issues in subsequent EA builds.
For some similar issues, see:
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1424598684
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1426005189
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1437471768
Workaround: Open "Tools | Options | Links" and clear the "Strict Connector Syntax" option
Please submit a bug report and we will investigate your specific issue further.  (See "Report a Bug" link at the foot of this page)
Tomasz
« Reply #3 on: September 08, 2015, 05:49:29 pm »
Thank you for quick answer.
Workaround works fine.
I will create a bug report today.
