Author Topic: C++ reverse engineering: using keyword parse error  (Read 4373 times)
Dustan Morgan
« on: September 09, 2015, 08:50:13 am »
Hi, I'm a new user to Enterprise Architect.  I'm trying to generate a class diagram from C++ code.  However, EA seems to be unable to handle the "using" keyword?
There was an error parsing blah.cpp  on line 26.  Unexpected symbol: using
This seems to happen with either usage of the "using" keyword
using namespace X
using myvar = int;
Is there some sort of work-around to get things running?
Re: C++ reverse engineering: using keyword parse e
« Reply #1 on: September 14, 2015, 09:03:10 am »
I would certainly expect using namespace to work (I've imported code containing that many times.) I'm not so sure about the type aliasing usage. (At least I think that's what you're trying to refer to, myvar implies you're expecting a variable instead) It was added in C++11
Look above line 26 for the likely problem. eg. Taking your two samples, it would get a parse error on the second using because of the missing semi-colon on the line above. (I realize that's probably not in your code.)
