Author Topic: Legend problems  (Read 4329 times)
Marianne
Legend problems
« on: October 06, 2015, 08:32:35 pm »
working on a local eap file, I create a legend in a diagram. I can add everything I want. When I save the diagram no error occurs. If I close and reopen the diagram the legend is empty (also all legends on all other diagrams at once). I only see the default title. I tried to repair the eap, to reset the ID's. But nothing works. :-/ Can this be solved? If no, would this also happen on a repository?
I'm using version 12.0.1214.
Kind Regards, Marianne
Re: Legend problems
« Reply #1 on: October 06, 2015, 08:39:16 pm »
Marianne,
Have you tried to do a Project Integrity Check (shift-F9)
Re: Legend problems
« Reply #2 on: October 06, 2015, 09:55:38 pm »
I faintly remember someone else posting here with legend issues. If nothing helps (means also if you can't find the post here) you need to contact Sparx support and prepare to send the model so they can debug.
