Author Topic: Copy Connectors not working  (Read 6072 times)
IvanoL
« on: November 05, 2015, 04:31:10 am »
EA Version: 12.0.1212
Action: paste of 2 connected blocks as instances in a new Object Diagram
Expected result: the instance blocks are pasted and linked
Actual result: the instance blocks are pasted without links
Thank you in advace for any support.
Best regards,
Ivano
Re: Copy Connectors not working
« Reply #1 on: November 05, 2015, 07:54:36 am »
How do you use the copy operation?
« Last Edit: November 05, 2015, 07:55:10 am by qwerty »
VKN
« Reply #2 on: November 05, 2015, 09:35:46 am »
When you select to drop the element as an instance, also check the Copy connectors option.
« Reply #3 on: November 05, 2015, 05:46:48 pm »
I just did that. The connectors were copied. What are the exact steps?
IvanoL
« Reply #4 on: November 05, 2015, 08:03:23 pm »
I'm pasting 2 blocks from the model tree to an Object Diagram as instance (by drag&drop), with "Copy Connectors" flag checked.
The pasted blocks are already connected by association in another Block Definition Diagram.
Ivano
« Reply #5 on: November 05, 2015, 10:07:44 pm »
I have been using classes. Are you by any chance talking about SysML blocks?
IvanoL
« Reply #6 on: November 05, 2015, 10:29:18 pm »
I found it.
The problem was i dragged one block/class a time, instead of selecting and dragging all of them in a single shot.
Thanks to all,
Ivano
