Author Topic: Subversion checkout not working  (Read 5478 times)
johnvk
« on: November 06, 2015, 01:40:09 am »
EA: 12.0 1215
svn client 1.9.1
I have a subversion repository with which I can do an add, update, commit, lock and unlock with the svn client. I configure EA to use the right path an add a package to it. This works. The package get checked in and I see a locked package in EA. When I try to checkou that package I get the error that the package is "Not controlled". I tried "Get latetst" and "resync" but this has no effect.
If I use the subversion client 1.8.8 then I can do a checkout. If there something changed in the client that EA cannot handle? Is there a solution?
PeterHeintz
Re: Subversion checkout not working
« Reply #1 on: January 21, 2016, 06:58:08 pm »
This is a problem I had when trying to switch from SVN 1.7 to 1.9. Neither upgrade nor clean up of the working copy solved the problem.
The workaround I used was creating a new EA project from scratch and checking out the data anew with SVN 1.9.
Best regards,
Peter Heintz
