Author Topic: direction of composition relation  (Read 12365 times)
aloeffen
« on: November 18, 2015, 12:34:16 am »
When I create a composition relation from whole to part, I see that source is part and target is the whole; I would expect the other way around.
Is this correct behavior and if so, does anyone known where this is described (in the UML standard)?
Thanks in advance,
arjan
Re: direction of composition relation
« Reply #1 on: November 18, 2015, 01:26:11 am »
That has been discussed long and broad here. The Quick Linker offers to do it both ways. You just need to get used to it. It's like USB: the first try doesn't work. You swap it. And recognize that the first time it was correct  ;D
Glassboy
« Reply #2 on: November 18, 2015, 07:39:19 am »
USBs exhibit non-quantum superpositions.
« Reply #3 on: November 18, 2015, 10:23:50 am »
It is said that once the person that invented the USB plug will die, he will be laid to his grave, taken out and turned around (twice?).
This year is 100th anniversary of e=mc2. What would Einstein and esp. Heisenberg say about USB?
« Last Edit: November 18, 2015, 10:24:30 am by qwerty »
« Reply #4 on: November 18, 2015, 03:45:24 pm »
For those that are annoyed by this source/target thing, I wrote a little script that sets them straight for compositions.
If you copy this script to a diagram group you can right click on a composition and execute the script for that single relation, or right click on a a diagram and do it for all relations in the diagram.
There is however something strange going on with the navigability. After reloading the diagram it shows arrow heads where it didn't show them before. I'm not sure why that happens.
Part 1 of the code
option explicit
!INC Local Scripts.EAConstants-VBScript
' Script Name: Set composition source and target
' Author: Geert Bellekens
' Purpose: Make sure that the whole end is always the source, and the part end is always the target
' Date: 18/11/2015
' Diagram Script main function
sub OnDiagramScript()
      ' Get a reference to the current diagram
      dim currentDiagram as EA.Diagram
      set currentDiagram = Repository.GetCurrentDiagram()
      if not currentDiagram is nothing then
            ' Get a reference to any selected connector/objects
            dim selectedConnector as EA.Connector
            set selectedConnector = currentDiagram.SelectedConnector
            if not selectedConnector is nothing then
                  'correct the composition direction for a single composition
                  correctCompositionDirection selectedConnector
            else
                  'correct the composition direction for all compositions in the diagram
                  dim diagramLink as EA.DiagramLink
                  for each diagramLink in currentDiagram.DiagramLinks
                        'get connector from diagram link
                        dim connector as EA.Connector
                        set connector = Repository.GetConnectorByID(diagramLink.ConnectorID)
                        'set composition source and target
                        correctCompositionDirection connector
                  next
            end if
      else
            Session.Prompt "This script requires a diagram to be visible", promptOK
      end if
end sub
OnDiagramScript
function correctCompositionDirection(relation)
      if relation.Type = "Association" or _
            relation.Type = "Aggregation" then
            'check aggregationKind
            if relation.SupplierEnd.Aggregation <> 0 _
                  and relation.ClientEnd.Aggregation = 0 then
                  'switch source and target
                  'switch ID's
                  dim tempID
                  tempID = relation.ClientID
                  relation.ClientID = relation.SupplierID
                  relation.SupplierID = tempID
                  'switch Ends
                  switchRelationEnds relation
                  'save relation
                  relation.Update
            end if
      end if
end function
« Last Edit: November 18, 2015, 03:45:41 pm by Geert.Bellekens »
« Reply #5 on: November 18, 2015, 03:46:11 pm »
Part 2 of the code
function switchRelationEnds (relation)
      dim tempVar
      tempvar = relation.ClientEnd.Aggregation
      relation.ClientEnd.Aggregation = relation.SupplierEnd.Aggregation
      relation.SupplierEnd.Aggregation       = tempvar
      tempvar = relation.ClientEnd.Alias
      relation.ClientEnd.Alias = relation.SupplierEnd.Alias
      relation.SupplierEnd.Alias             = tempvar
      tempvar = relation.ClientEnd.AllowDuplicates
      relation.ClientEnd.AllowDuplicates = relation.SupplierEnd.AllowDuplicates
      relation.SupplierEnd.AllowDuplicates   = tempvar
      tempvar = relation.ClientEnd.Cardinality
      relation.ClientEnd.Cardinality = relation.SupplierEnd.Cardinality
      relation.SupplierEnd.Cardinality       = tempvar
      tempvar = relation.ClientEnd.Constraint
      relation.ClientEnd.Constraint = relation.SupplierEnd.Constraint
      relation.SupplierEnd.Constraint        = tempvar
      tempvar = relation.ClientEnd.Containment
      relation.ClientEnd.Containment = relation.SupplierEnd.Containment
      relation.SupplierEnd.Containment       = tempvar
      tempvar = relation.ClientEnd.Derived
      relation.ClientEnd.Derived = relation.SupplierEnd.Derived
      relation.SupplierEnd.Derived           = tempvar
      tempvar = relation.ClientEnd.DerivedUnion
      relation.ClientEnd.DerivedUnion = relation.SupplierEnd.DerivedUnion
      relation.SupplierEnd.DerivedUnion      = tempvar
      tempvar = relation.ClientEnd.IsChangeable
      relation.ClientEnd.IsChangeable = relation.SupplierEnd.IsChangeable
      relation.SupplierEnd.IsChangeable      = tempvar
      tempvar = relation.ClientEnd.IsNavigable
      relation.ClientEnd.IsNavigable = relation.SupplierEnd.IsNavigable
      relation.SupplierEnd.IsNavigable       = tempvar
      tempvar = relation.ClientEnd.Navigable
      relation.ClientEnd.Navigable = relation.SupplierEnd.Navigable
      relation.SupplierEnd.Navigable         = tempvar
      tempvar = relation.ClientEnd.Ordering
      relation.ClientEnd.Ordering = relation.SupplierEnd.Ordering
      relation.SupplierEnd.Ordering          = tempvar
      tempvar = relation.ClientEnd.OwnedByClassifier
      relation.ClientEnd.OwnedByClassifier = relation.SupplierEnd.OwnedByClassifier
      relation.SupplierEnd.OwnedByClassifier = tempvar
      tempvar = relation.ClientEnd.Qualifier
      relation.ClientEnd.Qualifier = relation.SupplierEnd.Qualifier
      relation.SupplierEnd.Qualifier         = tempvar
      tempvar = relation.ClientEnd.Role
      relation.ClientEnd.Role = relation.SupplierEnd.Role
      relation.SupplierEnd.Role              = tempvar
      tempvar = relation.ClientEnd.RoleNote
      relation.ClientEnd.RoleNote = relation.SupplierEnd.RoleNote
      relation.SupplierEnd.RoleNote          = tempvar
      tempvar = relation.ClientEnd.RoleType
      relation.ClientEnd.RoleType = relation.SupplierEnd.RoleType
      relation.SupplierEnd.RoleType          = tempvar
      tempvar = relation.ClientEnd.Stereotype
      relation.ClientEnd.Stereotype = relation.SupplierEnd.Stereotype
      relation.SupplierEnd.Stereotype        = tempvar
      tempvar = relation.ClientEnd.StereotypeEx
      relation.ClientEnd.StereotypeEx = relation.SupplierEnd.StereotypeEx
      relation.SupplierEnd.StereotypeEx      = tempvar
'      tempvar = relation.ClientEnd.TaggedValues
'      relation.ClientEnd.TaggedValues = relation.SupplierEnd.TaggedValues
'      relation.SupplierEnd.TaggedValues      = tempvar
      tempvar = relation.ClientEnd.Visibility
      relation.ClientEnd.Visibility = relation.SupplierEnd.Visibility
      relation.SupplierEnd.Visibility        = tempvar
      relation.ClientEnd.Update
      relation.SupplierEnd.Update
end function
robinch
« Reply #6 on: November 18, 2015, 09:53:29 pm »
With the introduction of Type-C connectors, USB beat Sparx in solving the problem though. And, whichever the cable, USB communication has always been bi-directional by default :).
« Reply #7 on: November 19, 2015, 01:11:00 am »
... communication has always been bi-directional by default :).
The problem here is that connectors as per specification do not have source and target but 2..* connecorEnds. S/T are EA-specific because they are stored this way in their database and do not hide this. Somehow one gets used to it.
« Last Edit: November 23, 2015, 05:45:33 pm by qwerty »
RIL
  • -- There's always a solution --
« Reply #8 on: November 23, 2015, 04:12:29 am »
Is it odd of me to expect the diagram represent ownership like so? :
[Whole]<.><-1--------*->[Part]I used Borland/CodeGear's ORM Framework named Bold Architecture, and there the "filled diamond" was placed on the whole-side.
In any case, since this is about "ownership" the Supplier end should (of course) be the Source, and in my EA version (12.1.1222) it is always drawing the connector (correctly) from Source to Target.
Trying to execute the script I found out that you guys seems to be content with having the diamond on the Parts side. How odd you are! :)
[Whole]<-1--------*-<.>[Part]// Rolf
[highlight][Edit][/highlight]: Fixed the navigability. BTW, in my own code generators I always interpret Unspecified as Navigable, and only by explicitly setting a role to Non-navigable I will suppress generating a member as Public.[/i]
« Last Edit: November 23, 2015, 01:04:22 pm by Rolf_Lampa »
« Reply #9 on: November 23, 2015, 11:08:17 am »
Hi Rolf,
Check out:
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1447148230/20#20
That may solve your problem.
RIL
« Reply #10 on: November 23, 2015, 12:58:31 pm »
Hi Paolo,
Yes, by mistake I made the link non-navigable towards the whole (I'll fix that).
Normally I always make "ownership" links navigable in both directions.
And I agree, since the single reference (to Whole) is technically speaking embedded as a property on the Part side, there's no option left, such an association is by implication always navigable both ways.
It's another thing though to indicate in the model that one should not navigate in a certain direction, by making one role "non-navigable", but technically speaking you will of course always be able to navigate in both directions anyway.
// Rolf
« Reply #11 on: November 23, 2015, 05:55:42 pm »
Turns out the script has a completely wrong effect when executed on v12. In v12.1 is actually does what it is expected to do.
I guess there was a bug in the API in v12 that got fixed in v12.1
