Author Topic: EA crashes when generating documentation  (Read 13470 times)
WzDrg
« on: December 04, 2015, 10:02:47 pm »
Enterprise Architect crashes when I try to generate documentation.
I get the following problem details
Problem signature:
  Problem Event Name:      APPCRASH
  Application Name:      EA.exe
  Application Version:      12.0.0.1211
  Application Timestamp:      551b61a7
  Fault Module Name:      TER81.dll
  Fault Module Version:      21.0.4.6
  Fault Module Timestamp:      5511f201
  Exception Code:      c0000005
  Exception Offset:      00104783
  OS Version:      6.3.9600.2.0.0.16.7
  Locale ID:      2067
  Additional Information 1:      5861
  Additional Information 2:      5861822e1919d7c014bbb064c64908b2
  Additional Information 3:      a10f
  Additional Information 4:      a10ff7d2bb2516fdc753f9c34fc3b069
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=280262
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
Any solution or workaround?
Thx.
Re: EA crashes when generating documentation
« Reply #1 on: December 04, 2015, 10:04:29 pm »
You might try to upgrade your EA version.
WzDrg
« Reply #2 on: December 04, 2015, 10:16:22 pm »
No fixes regarding the generation of documentation were mentioned in the release notes. In what version is this crash fixed?
« Reply #3 on: December 04, 2015, 10:36:51 pm »
Have you reported the issue to Sparx?
I don't think this is a general issue since I've been generating documents without issues on both v12 and 12.1
Marilynn101
« Reply #4 on: January 16, 2016, 08:45:09 am »
I am having this same issue. I reported it to Sparx. The application crashes repeatedly when creating large custom documents or running the document generator. Are there any workarounds or solutions?
Glassboy
« Reply #5 on: January 18, 2016, 07:14:23 am »
In general, when any application that renders documents into graphical or print ready formats crashes repeatably you should have a cleanup of temp files and run checkdisk.  Often the crashes are caused by hitting cross-linked files when writing large temporary files.
Bleachbit http://bleachbit.sourceforge.net/ is an excellent tool for cleaning all of the detritus out of your file system.
Marilynn101
« Reply #6 on: January 20, 2016, 02:33:11 am »
I cleaned up the temp files and checked the disk. Still crashing.
« Reply #7 on: January 20, 2016, 08:54:23 am »
Try build 1226. It contains a fix for a crash during generation. I hope it's the same one you're experiencing...
