Author Topic: Generating DDL Schema  (Read 46986 times)
Keith Bollwahn
« on: December 03, 2001, 12:21:36 pm »
 ??? When generating DDL from EA, is there a way to reset the target path to null so the application will prompt for a target the next time I run the generation?
sparks
Re: Generating DDL Schema
« Reply #1 on: December 04, 2001, 03:43:40 am »
I am assuming you have been generating DDL from the package level, so you do a group of tables at one time.  ie the bulk generate.
The alternative to this is to generate each table individually.  To do this right click on a table and select "Generate DDL..." you will be shown a screen where you can change the output filename and if you want, generate the DDL SQL for the selected table.
Hope this helps.
Paul Mathers
