Author Topic: Data Model Column Constraints  (Read 25494 times)
greygor
  • I love YaBB 1 Gold!
« on: January 10, 2002, 02:31:33 am »
I'm probably  being a bit dumb, but I'm trying to do a data model using EA and I want to put a constraint on a column such that;
If Table1.Column1 = "2" then Table1.Column2's value must exist in Table2
How do you specify this?
sparks
Re: Data Model Column Constraints
« Reply #1 on: January 13, 2002, 04:32:52 pm »
By the sounds of what you are describing, the relationship is a foreign key, is this right?  Probably the easiest way to explain how to document a foreign key in UML is to download a copy of the DatabaseModelingInUML.pdf that we have available here:  http://www.sparxsystems.com.au/bin/DatabaseModelingInUML.pdf
It is worth having a read through the Data Modeling pdf, if you plan to use EA to document your database design etc.
Hope this helps.
Paul Mathers
