Author Topic: Version 3.60 - Build 658 Released  (Read 21924 times)
sparks
« on: January 14, 2004, 10:27:51 pm »
Changes and Fixes in Version 3.60 - build 658
Corrected issue with Unicode build that prevented use of JET 4.0 to access models or import MS Access 2000 or higher database schemas
Fixed VBNet function identifier behaviour which prevented keyword function identifiers to be properly imported.
Fixed UML Profile import process to correct an issue where SPEM profile images were not being properly imported.
Fixed XMI import error when reloading new XMI controlled packages.
Fixed issue with saving of decimal values in requirements types dialog when locale uses , for decimal point
Fixed problem with automation interface when reading IsStatic, IsSynchronized and IsAbstract properties of Method
