Author Topic: C# property code generation  (Read 16700 times)
swells
  • Really Penfold!
« on: February 02, 2002, 12:38:28 pm »
The code generation for C# properties is not using the standard property code, but instead creating methods.
For a property called MyProperty it should read:
int miMyProp;
Public int MyProperty
  get
     return miMyProp;
  set
     miMyProp = value;
It would also be 'nice' for the code to be generated as well (after all the modeller does know which attribute is used for the property).
« Last Edit: February 02, 2002, 12:39:05 pm by swells »
gsparks
  • I love YaBB 1 Gold!
Re: C# property code generation
« Reply #1 on: February 03, 2002, 03:33:19 am »
We are currently updating the code generation in EA and this item is one that has been fixed. A minor update will be released in a week or so with this change plus a lot of others in the code forward and reverse engineering area.
Hope this helps,
Geoff Sparks
