Author Topic: Entity Relationship Diagram  (Read 22725 times)
swells
  • Really Penfold!
« on: February 12, 2002, 01:25:39 pm »
i have had difficulty generating FK in the generated code. The association for an ERD is not in the left pane, but taking a normal association and changing the type is OK - however if you change the type to before you have set up the FK you can't create the FK. You have to do it whilst it is still an association then change the type.
Also the help say 'parameter tab' but it is actually the 'columns tab'.
Anyone found any other way to get FK to generate successfully.
