Author Topic: Reverse Engineering - Problems with Friends  (Read 8757 times)
Si Perry
« on: February 12, 2002, 09:01:27 pm »
Hi
I have a file of the form:
class NovaDate
   // FRIENDS
   // @friend NovaTime | Time (and date) class
   friend class NovaTime;
   friend class NovaDSTBoundary;
// @access Public Members & Methods
public:
     NovaDate();
// etc other methods and members here
When I reverse engineer this class I get a dialog saying "Error Reading File".
When I hit okay, the file seems to import. However, on viewing the class, a number of problems exist:
1. ALL the methods AND members have been marked as friend and hence do not appear in the class diagram.
2. Some members, of the form
   static const unsigned ms_DaysInMonth[12];
   static const unsigned ms_FirstDayOfEachMonth[12];
are incorrectly imported. They have no name, and the name is used as the type.
3. Some methods, for example
unsigned dayOfMonth() const;
are incorrectly imported. They have no type, and name unsigned dayOfMonth.
Can anyone advise?
Si
TorbenKoch
Re: Reverse Engineering - Problems with Friends
« Reply #1 on: February 13, 2002, 05:20:02 am »
I am using EA 3.10 build 461.
I am not sure whether my problem is caused by the same as yours, but I also do get the Error reading file error when reading the following:
class OutputPort : public JobReceivingModule
//!Construction:
public:
     // Construct an output port, using the passed configuration.
     OutputPort(const String &moduleName, ModuleConfiguration *configuration, CommController *comm);
     virtual ~OutputPort();
     virtual String      getModuleType();
protected:
     void onPauseProcessing() { JobReceivingModule::onPauseProcessing(); }
     void onScheduler(int ScheduleID) { }
     void onStopProcessing()      { JobReceivingModule::onStopProcessing(); }
     void onStartProcessing() { JobReceivingModule::onStartProcessing(); }
What is actually imported looks like this when generated:
public:
     OutputPort();
public:
     OutputPort(const String& moduleName,ModuleConfiguration* configuration,CommController* comm);
protected:
     void onPauseProcessing();
As it can be seen it is clear that everything that follows an inline function is not imported  8).
I'm glad that it's not me who's building this importer...! ;)
