Author Topic: Track occurrence of elements on diagrams?  (Read 4214 times)
Arjen
« on: November 11, 2006, 01:22:16 am »
Is it possible to find on which diagrams model elements occur?
Context: I've been building some models with lots of unnamed startactivities. Also, I've deleted a number from diagrams, but not from the model. Now I'd like to cleanse my project view from all unused startactivities. However, I see no possibility to distinguish the 'orphans' from the ones in use.
Again: thanks for any help!
Arjen
Re: Track occurrence of elements on diagrams?
« Reply #1 on: November 11, 2006, 01:43:04 am »
Hi Arjen,
Are you wanting to do this specifically under automation?  If not, then Search Project [Ctrl+F] has a predefined search that will find orphans and may select the things you want...  Certainly it should be modifiable to your needs.
« Reply #2 on: November 13, 2006, 06:55:53 am »
From an element use Ctrl+U
From automation you need to recurse through the project view.
Aaron B
« Reply #3 on: November 13, 2006, 02:49:13 pm »
From Automation, you can also call the Find Orphans search using Repository.GetElementsByQuery which returns a collection of elements matching the search criteria (added in EA 6.5.795).
Dim results as EA.Collection
Set results = Repository.GetElementsByQuery("Find Orphans", "")
