Author Topic: Feature Request: re Spaces in Attribute Names  (Read 21074 times)
kiwi
  • I love YaBB 1 Gold!
« on: February 28, 2002, 04:22:30 am »
Hi all,
If you put a space in an attribute name, it gives a warning that it might give code generation problems.
What I propose is a very simply and easy-to-implement set of mapping conventions one can use. The most common that Java developers will use is like this:
1) Remove all spaces (simply concatenate words together)
2) make the first letter of the resulting string lower case.
I think this is how C# works too but I don't know
Others can be just as simple:
1) replace all spaces with underscores
Similar ideas can be done with table name mapping as well, but it would probably be different, something more like:
1) replace spaces with underscores
2) convert all letters to uppercase
cheers!
