Author Topic: Delphi - Generated Code  (Read 7106 times)
greygor
  • I love YaBB 1 Gold!
« on: March 28, 2002, 04:38:04 am »
I think this will be the last request as it is now virtually working.  Just one little niggle.
Here is the source that was reverse engineered;
  TMammal = class(TObject, ICommunicate)
 private
   FEyeColour: TColor;
   FEyeColour2: TColor;
   procedure SetEyeColour(const Value: TColor);
   procedure SetEyeColour2(const Value: TColor);
 protected
   function Agree(Message: string): Boolean;
 published
   property EyeColour: TColor read FEyeColour write SetEyeColour;
   procedure Testing;
 public
   procedure Speak(Message: string);
   property EyeColour2: TColor read FEyeColour2 write SetEyeColour2;
 end;
Code Generated after import into EA
 TMammal = class (ICommunicate)
private
     FEyeColour: TColor;
     procedure   SetEyeColour(Value: TColor);
     procedure   SetEyeColour2(Value: TColor);
protected
public
published
     procedure   Testing;
     property EyeColour:TColor read FEyeColour write SetEyeColour;
 end;
Two things;
1: A class Type is required so
  TMammal = class(TObject, ICoomunicate) should have been generated.
2: The public property EyeColour 2 was missed, but not the private field or procedure relating to it.
BTW, can I just congratulate you on the speed of response to these delphi issues, it is very much appreciated.
Mark Stansfield
Senior Developer/Trainer
www.runtimetechnology.co.uk
gsparks
Re: Delphi - Generated Code
« Reply #1 on: April 01, 2002, 04:08:03 pm »
Hi again,
I have checked these out and made the appropriate fixes.
Both public and published properties will now generate the first time, and if a class does not have an explicit parent, it is given the TObject ancestory, even when an Interface is implemented.
These will be in the next update - look for a build of 479 or higher. It should be available in the next day or so.
Thanks for the example and suggestions,
Geoff Sparks
