Author Topic: Problems viewing diagram  (Read 4571 times)
jamesp
« on: April 08, 2002, 11:02:04 am »
   I am evaluating the code for reverse engineering reasons.  I have a small test program that I thought I would load in and then look at a diagram.   I import the files into the diagram area, I get a box that shows the files coming and and a ok message at the end.   What do I do to see them show up int the right window?  (Diagram area)   Also is there a list of the files that I can look at somewhere?
James
gsparks
  • I love YaBB 1 Gold!
Re: Problems viewing diagram
« Reply #1 on: April 08, 2002, 03:34:16 pm »
Hi James,
If you followed the steps to import from source, then the imported elements should show up in the diagram straight away.
Do you have an example of the files you were importing so I can check there is no problem? You could send to me at:
Geoff Sparks
