Author Topic: Invoking a Base Class Constructor in C++  (Read 7317 times)
Zidane
« on: November 09, 2006, 09:04:37 am »
If I manually change a constructor to invoke a constructor of the base class, this info is deleted with the next code generation / synchronisation loop.
Example:
GENERATED HEADER FILES
class A
A(int x);
class B : private A
B(int x);
GENERATED CPP FILES
A::A(int x){}
B::B(int x){}
Now I change last line manually to
B::B(int x):A(x){}
which would be okay,
but after next synchronization this change is lost.
Any idea?!?
Best regards,
DD.
Re: Invoking a Base Class Constructor in C++
« Reply #1 on: November 09, 2006, 12:59:52 pm »
EA is removing the inialization list because it expects to it to be defined in a tagged value "initializer" on the constructor.  If you add this tagged value then things should work as expected.
For more information on how C++ is modelled in EA please see http://www.sparxsystems.com.au/EAUserGuide/index.html?cpp_conventions.htm
Zidane
« Reply #2 on: November 17, 2006, 02:16:45 pm »
Forgot to say: Thank you  ;D
