Author Topic: code gen. advanced 'v' default options  (Read 12585 times)
bob lytton
« on: April 19, 2002, 03:56:36 am »
I'm using build 477.
I assumed that setting "View->Options->Generation->Object lifetimes" would set the default options for the current project.
I find that new classes do not always take up these options by default, neither are they displayed under "Advanced" in the "Code generation->Generate code" dialog.
Also when exporting several classes with "Generate all selected objects with default options", it does do as I expect (use last used values instead?).
I found at one stage that I had ticked "Generate copy constructor" and could not un-tick a batch of classes but had to do them individually. Having the "Generate all selected objects..." allowing you to go to  "Advanced" and then "Save" would be useful!
b.
